Can I bar certain outgoing codes (ie 07's ,09's)
caccy
Can anybody help please.
Is it possible to set Home Phone up so that premium rate and mobiles cannot be dialed?
This does not seem to be mentioned in the "help topics".
5 REPLIES 5
penfold
Fixes: 5
Re: Can I bar certain outgoing codes (ie 07's ,09's)
Hi
I would like this as well, as I sometimes forget not to dial 07 and 08 numbers. If not can it be added as a PUGIT?? ( not sure how to do it really  ???)
Mand
We don't currently offer this service as a feature, although it's definitely something which is on the list as it's asked for regularly. We're looking at bringing this onboard within the next few months.
I'm sure there was a PUGIT raised for it already somewhere, will have a dig around tomorrow.
Strat
Fixes: 565
It's been mentioned in other threads very recently.
pierre_pierre
Grin Try Search you never know what you might not find Grin
Strat
Fixes: 565
Quote from: pierre_pierre
I find a lot.....unfortunately it's totally unrelated to what I was searching for Angry
Mods: Sorry about the full quote Sad
