Can I bar certain outgoing codes (ie 07's ,09's)
- Home Phone
- Re: Can I bar certain outgoing codes (ie 07's ,09'...
05-02-2008 2:36 PM
Can anybody help please.
Is it possible to set Home Phone up so that premium rate and mobiles cannot be dialed?
This does not seem to be mentioned in the "help topics".
Message 1 of 6
(2,187 Views)
5 REPLIES 5
Re: Can I bar certain outgoing codes (ie 07's ,09's)
05-02-2008 4:16 PM
Hi
I would like this as well, as I sometimes forget not to dial 07 and 08 numbers. If not can it be added as a PUGIT?? ( not sure how to do it really ???)
Message 2 of 6
(515 Views)
05-02-2008 8:08 PM
We don't currently offer this service as a feature, although it's definitely something which is on the list as it's asked for regularly. We're looking at bringing this onboard within the next few months.
I'm sure there was a PUGIT raised for it already somewhere, will have a dig around tomorrow.
Message 3 of 6
(515 Views)
05-02-2008 8:17 PM
It's been mentioned in other threads very recently.
Message 4 of 6
(515 Views)
05-02-2008 8:20 PM
Try Search you never know what you might not find
Message 5 of 6
(515 Views)
05-02-2008 8:22 PM
Quote from: pierre_pierre Try Search you never know what you might not find
I find a lot.....unfortunately it's totally unrelated to what I was searching for
Mods: Sorry about the full quote
Message 6 of 6
(515 Views)
- Home Phone
