Calls to 123 that are actually Openreach engineers test calls
MartinC
Can you not find a way of stopping this? After all you are owned by BT and so is Openreach.
I have two charges (7th July). One is even for zero minutes!! Could you also explain how you can be charged for a zero call.
3 REPLIES 3
198kHz
Fixes: 41
Re: Calls to 123 that are actually Openreach engineers test calls
It's a commonly recurring theme on the forum  Sad
The problem only entered public consciousness with the advent of fully itemised billing in the 80s, but it's been around for a lot longer than that, with no realistic prospect of a solution. See:
https://community.plus.net/t5/Plusnet-Feedback/Charges-to-123/td-p/1808477
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
flanzm
Fixes: 15
After 2025 it won't be a problem anymore.  Once we have retired the PSTN phone network and everyone moved to VoIP no Openreach engineer will be able to dial any numbers on your line by just attaching a phone.
adam945
Fixes: 113
Thanks for reaching out @MartinC
Unfortunately, there's not much we can do on our end with regards to how Openreach engineers test the line, though I agree that they ought to be more mindful that these calls do add extra charges onto your bill.
Anyway, I've refunded the extra amount and have sent you a confirmatory email if you'd like to have a look. Feel free to reach out if you have any further issues/ queries.
 Adam
 Plusnet Help Team - Leeds
