Caller id stopped working at noon
map1984
Hi, I noticed that calls are now just showing as incoming calls, I logged into plus net and there's a little green dot next to caller display in call features. Thanks for any help.
2 REPLIES 2
map1984
Re: Caller id stopped working at noon
OK, to update, numbers are showing up, but I believe only from landlines, trying from my mobile (not WiFi) it just says incoming call, is that correct? Thanks
adamwalker
Fixes: 217
Hi there, caller display should work from mobiles too as long as the number isn't being withheld by the caller, some phones have a setting for this "show caller ID" so you might want to check that's enabled.
 Adam Walker
