Caller id stopped working at noon
- Home Phone
- Re: Caller id stopped working at noon
16-12-2019 8:38 PM
Hi, I noticed that calls are now just showing as incoming calls, I logged into plus net and there's a little green dot next to caller display in call features. Thanks for any help.
Message 1 of 3
(757 Views)
2 REPLIES 2
17-12-2019 5:11 PM
OK, to update, numbers are showing up, but I believe only from landlines, trying from my mobile (not WiFi) it just says incoming call, is that correct? Thanks
Message 2 of 3
(712 Views)
18-12-2019 2:19 PM
Hi there, caller display should work from mobiles too as long as the number isn't being withheld by the caller, some phones have a setting for this "show caller ID" so you might want to check that's enabled.
Message 3 of 3
(689 Views)
- Home Phone
