Caller id not working
Slarti997
Since switch over on 5th June 2023 we've had no caller id
6 REPLIES 6
Fixes: 1,662
Re: Caller id not working
Hi @Slarti997
I've placed an order to enable caller display which should be active within 24 hours.
Let us know if there are any issues.
Slarti997
Appears OK now Gandalf. Many thanks for tidying things up so swiftly.
Haz123
Unable to post , no button showing. I also have this nocaller id showing
James30
Fixes: 32
@Haz123 All sorted, just needed some tinkering at my end. Give it 24 hours for the caller display to start working. I've left a note on your account about something if you could reply and let me know @ https://www.plus.net/wizard/?p=view_question&id=238594756
James - Plusnet Sheffield
Haz123
Not sure if my reply got there.
Thanks for fixing caller id. Will check tomorrow if working.
Don't want voicemail feature if it conflicts with phone voicemail future Thanks
James30
Fixes: 32
Brill that's you all sorted then just give us a shout if it's still not working tomorrow.
