Caller id not working
- Home Phone
- Caller id not working
09-03-2019 10:18 AM
I have recently ported over to plusnet; but the caller id feature is switched on but not working. I did try the *#234# code sequence but it comes back as service not available.
Thanks,
Darren
Re: Caller id not working
09-03-2019 11:26 AM
09-03-2019 11:47 AM
I did check that before testing and it’s green on the website.
Thanks,
09-03-2019 12:03 PM
It should therefore be working!!
Without knowing the brand/style of phone, I really can't see why it's not displaying the numbers - guess it was fine with the previous provider?
I think you'd be best to hang on and wait for one of these wonderful, hard working, dedicated Plusnet forum staff so s/he can check if their systems are holding C/D off from working, even though yours is showing green!!
09-03-2019 1:13 PM
It's a fairly common problem when switching to Plusnet.
It's usually sorted by one of the Plusnet Help Team getting the feature removed and then applied again, as in this thread -
https://community.plus.net/t5/Home-Phone/Caller-Display-Not-Working/m-p/1618594#M28679
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
09-03-2019 6:44 PM
Thanks for responding anyway
09-03-2019 7:25 PM - edited 09-03-2019 11:31 PM
A little confused here
Openreach, afaik, do not have any control over caller display....?
I did note the *#234# code earlier, though now I'm not sure that actually works on Plusnet
That code, seems to be BT Business - bt business how to display and switch off caller id
I thought the only way we could do this was via our control panel - plusnet phone call features
I guess you'll have to wait and see what Plusnet do to resolve this for you
edit. Further info. I've just found this which could explain why it's not working, though you should have been told
Plusnet Call Protect and Caller Display are not available in a small number of locations, we will confirm if this applies to you after you have placed your order in your online account.
on 10-03-2019 6:41 PM - last edited on 10-03-2019 7:34 PM by Mav
It’s been resolved in 24 hours so thanks plusnet. Appears it was a line fault of some sort.
I can now safely avoid answering the phone to the mother-in-law... or ppi spammers.
(Only joking mum)
Moderator's note by Mike (Mav): Personal information removed from attachment in a public forum (to an area that staff can see).
10-03-2019 6:50 PM
Bizarrely, the same applies here too!!
Glad to hear it's sorted!
(enjoy the peace and quiet)
11-03-2019 12:24 PM
