Caller display
Kanthima
Caller display
Home-Phone/Caller-Display-Not-Working
2 REPLIES 2
Fixes: 411
Re: Caller display
Have you switched it on or at least gone into your account and checked that it's on?
OllieC
Fixes: 46
Re: Caller display
Hi @Kanthima
You can check your line by dialling *#234# if your line states that Caller Display is not active, please then dial *234#
This should then activate Caller Display on your line if the service has been taken out by yourself.
If this doesn't help please feel free to PM your account username as we are more than happy to look into this for you.
Kind Regards
