Caller display not working
Grhmeh
Just noticed my caller display does not work, can you look into it please.
3 REPLIES 3
MatthewWheeler
Fixes: 478
Re: Caller display not working
I've checked our suppliers system and it is showing as active from what I can see.
Can you try carrying out the steps below?
Dial *#234# from the phone that you want to use for caller display. Listen to the message.
  • If it says ‘unavailable’, you don’t have caller display at the moment.
  • If it says ‘the service is disabled’, you can enable it by hanging up and dialling *234#.
  • If it says ‘identities will be displayed’, but your caller display isn’t working, you’ll either need to use a different phone, or try these steps.
    1. Plug a corded phone that’s compatible with caller display into the master socket (the master socket’s the first socket where the phone line comes into your home).
    2. Call your number from another phone.
Let us know how you get on.
 Matthew Wheeler
Grhmeh
When I dialled #234# the message said caller identity will not be displayed , when I dialled *234# it started to work, thank you very much problem sorted.
MatthewWheeler
Fixes: 478
Glad to hear it's working!
 Matthew Wheeler
