Caller display not working
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Caller display not working
10-05-2019 9:53 AM
Thanks for getting in touch @carlozisa
I'm sorry to hear that your caller display isn't working.
I've looked into this and it appears that whilst the feature shows as active on our end it isn't on our suppliers.
This has now been rectified and it should be working now.
Let us know if you're still having issues
12-05-2019 8:10 PM
Works perfectly now - that did the trick.
Many thanks for your help!
13-05-2019 10:12 AM
Thanks for letting us know, @carlozisa
If we can ever be of more help then please don;t hesitate to get in touch.
Kind Regards,
MoR
06-07-2019 9:44 AM
I have the same problem.
#234# gives the "service unavailable" recording.
Can you pls fix it for me?
06-07-2019 12:59 PM
I'm really sorry to hear that your caller display isn't working. It shows active against your account.
To check that your caller display is active, please dial *#234# if it states that caller display is inactive or unavailable, please then dial *234# this is the correct way to manually activate it on your line.
Please let me know how you get on.
Kind Regards
06-07-2019 3:07 PM
I get "service unavailable" recording.
07-07-2019 8:19 AM
Hi @NoelMorgan21,
I've checked over your account and the line and while caller display does show as being active on your account, it unfortunately looks like the advisor who manually placed your order failed to include caller display so it's not actually on the line.
I do sincerely apologise this was missed from the initial order and then not picked up sooner when reporting the problem.
I've now placed an order to correct this. While we always have to advise up to 1 working day for these types of orders to complete, they generally complete very quickly on the same day, so I'd expect that to be active shortly for you.
I hope this helps.
08-07-2019 5:19 PM
Cheers that’s sorted now.
Noel
08-07-2019 5:22 PM
24-07-2019 5:38 PM
My caller display doesn’t work. I’ve tried #234# - service unavailable - can you help? Changed to plusnet about 6 weeks ago
24-07-2019 6:51 PM
Hi @Skelton35,
I am sorry to hear about your caller display not working and I apologise for the frustration caused to you.
I have removed and added your caller display feature back on in hopes this fixes the issue. Please could you try dial #234# and let us know how you get on?
I have also added a ticket on your account for visibility, you can view the ticket here.
Thanks.
28-08-2019 5:11 PM
Hi
My Caller Display has decided to stop working.
I've switched the phone off and on again and tried #234# (where do people find out these things?) and I'm told it's not available.
Hopefully it's a simple fix at your end.
Many thanks in advance.
Rick
28-08-2019 6:31 PM
Hi Rick. I'm sorry to see your caller display isn't working, I've reported this as a fault through to Openreach now and we've been provided an estimated response time of by 30/08/19 23:59:59 for an engineer to go out and investigate further.
Let us know how it goes over the next few days.
28-08-2019 9:41 PM
Thanks Gandalf, I was hoping it could be fixed in the same manner as others in this thread. I should be at home most of the time over the next 2 days though.
Regards
28-08-2019 9:54 PM
- Home Phone
