Caller display not working
abass001
My service started yesterday and although my account states that caller display is active it isn’t working, I just get ‘external call’ on my phone’s display.
I have tried *#234# and get the message sorry the service requested is not available.
How can I get this corrected please?
Many thanks,
Andy
40 REPLIES 40
MatthewWheeler
Fixes: 479
Re: Caller display not working
Sorry to hear your caller display isn't working.
I've checked on our supplier's systems and it seems it wasn't active there despite being on your account.
This has now been added manually for you and it should be up and running within the hour.
Let us know if you're still having issues after.
 Matthew Wheeler
Annlogan
I have the same problem and have been with plus net for 3 months now.
MatthewWheeler
Fixes: 479
@Annlogan Sorry to hear this.
So we can investigate further can you dial *#234# from the phone that you want to use for caller display. Listen to the message.
  • If it says ‘unavailable’, you don’t have caller display at the moment.
  • If it says ‘the service is disabled’, you can enable it by hanging up and dialling *234#.
  • If it says ‘identities will be displayed’, but your caller display isn’t working, you’ll either need to use a different phone, or try these steps.
    1. Plug a corded phone that’s compatible with caller display into the master socket (the master socket’s the first socket where the phone line comes into your home).
    2. Call your number from another phone
Let us know how you get on -Matt
 Matthew Wheeler
Annlogan
It says the service requested is not available.
abass001
Matthew, you are a star! Thanks so much, all working fine now 😀
MatthewWheeler
Fixes: 479
@Annlogan We've removed and readded the caller display which should have fixed this
Can you try again?
@abass001 Glad to hear it! -Matt
 Matthew Wheeler
Annlogan
Thank you matthew all working now 🎉🎉
MatthewWheeler
Fixes: 479
Glad to hear it!
Let us know if you have any further issues
 Matthew Wheeler
gwbiz07
I have the same problem.
#234# gives the "service unavailable" recording.
Can you pls fix it for me?
Mads
Fixes: 79
  Hello @gwbiz07,
Thanks for getting in touch and running that test, I have checked over your line and created a ticket with further information. You can view it here.
Deeppan
*#234# gives the "service unavailable" recording.
gwbiz07
This needs a manual fix by the tech people at PlusNet.
Once they have monitored your post, they will prob be in touch to raise a ticket.  Mine was fixed within 24 hours.
It seems to be a known fault but, as ever with Plusnet, the service is quick & effective.
MatthewWheeler
Fixes: 479
@Deeppan Sorry to hear this.
I've removed and readded the caller display feature for you which usually fixes this issue
Can you try it again?
 Matthew Wheeler
carlozisa
Hello Matthew
I have the same problem, with caller display not working on my phone and also being reported as unavailable on *#234# despite it showing as an "active" call features on my account dashboard.
Could you check this for me please?
