Caller display not working - new customer
- Home Phone
- Re: Caller display not working - new customer
11-05-2018 10:51 AM
Hello,
I switched from talk talk to PlusNet - 09.05.18.
The caller displays doesn't seem to have kicked in as yet.
Could this be looked at please?
Thank you
11-05-2018 10:59 AM
If not then you need to do so, if so then someone will pick it up from PN hopefully.
11-05-2018 11:17 AM
hello,
I've looked on the dashboard it is showing with a green block against caller display.
I selected it when I signed up.
11-05-2018 11:38 AM
Thanks for getting in contact @wolowizard
It looks like caller display hadn't correctly been ordered on the phone line. I have placed the order for you now and it should be active for you in the next 24 hours.
Apologies for the inconvenience this has caused.
- Home Phone
