Caller display not working following switch
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Caller display not working following switch
09-07-2021 11:51 AM
Hi, have recently switched to Plusnet but caller display is not working - this is active on account and worked with previous provider. Thanks
Fixed! Go to the fix.
09-07-2021 2:46 PM
Thanks for your post @sefm2910 and welcome to our Community Forums.
I'm sorry to see caller display doesn't work following transferring to us.
I've now placed an order with our suppliers to activate this along with the other call features showing active on your account that aren't active at our suppliers end. Looks like we hadn't provisioned your line with them initially.
The call features should start working by tomorrow.
10-07-2021 4:59 PM
Many thanks @Gandalf for the prompt response and action. I can indeed confirm that all call features, including caller display, are active today. Cheers 👍
10-07-2021 5:07 PM
Awesome! No problem at all @sefm2910
Let us know if there are further issues or anything else you'd need help with.
27-07-2021 2:05 PM
I've had exactly the same problem since switching from BT six months ago. Can you check if it is the same issue of Caller Display not being activated at the supplier, please.
27-07-2021 4:38 PM
Thanks a lot for reaching out @dominicripley
Please accept our apologies for this, usually, our automated system automatically places the orders to enable both Caller Display and Voicemail 1571 onto the line when provisioning the service. Although for some unknown reason, this has not been the case with your line.
Not to worry, both services will now be on your line by the end of the day, I've just placed the orders with Openreach to get this sorted.
Give us a shout tomorrow if you're still having problems with this, we'll be more than happy to investigate.
07-08-2021 1:44 PM
I'm also having this issue with caller display not working following switch to Plusnet. Appreciate if you'd also be able to escalate and have this fixed. Thank you
07-08-2021 5:08 PM
Hi @noelmallan,thanks for getting in touch and I'm sorry to hear not seeing your caller display active currently. I can see looking over your account the call feature is active on there but when checking our suppliers side the call feature is missing. In which case, I've added this on our suppliers side and this should come active by this time tomorrow at the latest for you. If the caller display is still not active by this time tomorrow then please get back in touch and we'll happily look into this further for you.
- Home Phone
