Caller ID?
- Home Phone
- Caller ID?
Caller ID?
05-03-2013 12:38 PM
I've never used this feature in my life.
Before starting paying £1 p.m. for the privilege, I want to make sure that my handset supports this.
The manual says:
Can anybody confirm that this will work and that it is just a matter of ticking "Caller Display" box in my "Home Phone Control Panel"?
The manual says:
The phone is Siemens Gigaset S5685 IP (S5675 IP?).
Quote When you receive a call from the fixed line network, the caller's number is displayed on the screen if the following conditions are met:
* Your fixed line network provider supports CLIP, CLI:
- CLI (Calling Line Identification): number of the caller is transmitted
- CLIP (Calling Line Identification Presentation): the caller number is displayed
* You have arranged CLIP with your network provider.
* The caller has arranged CLI with the network provider
Message 1 of 5
(1,108 Views)
4 REPLIES 4
Re: Caller ID?
05-03-2013 12:40 PM
Yup - it will work fine.
Message 2 of 5
(464 Views)
Re: Caller ID?
05-03-2013 12:48 PM
Actually I'll amend that to it "should" work fine.
My Gigaset (non IP) phones are all happy with the CLID that Plusnet send.
Message 3 of 5
(464 Views)
Re: Caller ID?
05-03-2013 12:56 PM
OK, thanks.
I'll try and see.
I'll try and see.
Message 4 of 5
(464 Views)
Re: Caller ID?
05-03-2013 3:13 PM
My Gigaset is fine with it, too, but I don't know if it's one of these "IP" phones (whatever that is).
Message 5 of 5
(464 Views)
