Caller ID not working
mcm553
Hi
My account says I should have Caller ID but it is not showing on my phone.
I have been a member for 1 month now.
My phone is compatible.
Thank you
3 REPLIES 3
MatthewWheeler
Fixes: 479
Re: Caller ID not working
Sorry to hear that.
I've checked your line and caller display is active so it should be working.
Can you try the steps below?
Dial *#234# from the phone that you want to use for caller display. Listen to the message.
  •     If it says ‘unavailable’, you don’t have caller display at the moment.
  •     If it says ‘the service is disabled’, you can enable it by hanging up and dialling *234#.
  •     If it says ‘identities will be displayed’, but your caller display isn’t working, you’ll either need to use a different phone, or try these steps.
  •         Plug a corded phone that’s compatible with caller display into the master socket (the master socket’s the first socket where the phone line comes into your home).
  •         Call your number from another phone.
 Matthew Wheeler
mcm553
Hi Matthew
Thanks for the reply.
I've tried what you suggested and was told 'the service requested is not available'
Is there anything else I can try?
SammyM
Fixes: 96
Hello @mcm553,
Sorry to hear you are experiencing problems with caller display. I have responded via your account here, with the next course of action. We really appreciate your patience in this matter and will keep you updated via your account.
 Sammy M - Sheffield Team
