Caller ID for incoming international calls (changes)
- Home Phone
- Caller ID for incoming international calls (change...
01-11-2013 10:06 AM
At the moment, you will either see:
INTERNATIONAL; or
UNAVAILABLE
This is not much use for knowing exactly who is calling, particularly given the issue of telemarketing calls from foreign call centres.
From Dec 2013 for 7 months, BT will be upgrading the exchange equipment to support international incoming caller line ID.
Once upgraded, anyone should see one of the following (if they have CLID and receive an international call):
Quote INTERNATIONAL and calling number - if the call is marked as International in origin
INTERNATIONAL and Withheld - if the caller has withheld their number
INTERNATIONAL and Unavailable - if there is no caller identity to be displayed
Re: Caller ID for incoming international calls (changes)
01-11-2013 10:58 AM
01-11-2013 7:30 PM
29-01-2014 4:15 PM
As soon as I changed to plusnet, I only get the id " international" which is truly not good enough!
Can you please explain why Sky with BT manages this fine, whereas Plusnet does not? Although I do not like Sky much, this is so important I may need to switch back.
29-01-2014 5:06 PM
29-01-2014 8:32 PM
I suspect that Sky and their technology is a little newer and better for the international CLID than the somewhat antiquated (but currently being upgraded) BT system. Heck - even the mobile phone companies have had international CLID for years.
It is on it's way on the BT system though so fingers crossed you'll be one of the earlier exchanges to be upgraded.
07-03-2014 5:29 PM
So might have to move back to Sky even though I am not really a Sky kind of person. (I'd rather support Plusnet, but this feature is important to me).
Kind regards,
07-03-2014 5:48 PM
Quote from: muse77 I just had a look at our exchange on the BT checker. It is accepting superfast broadband orders so presumably has been update
The problem is nothing to do with the Broadband component of the service, it is a feature within the Telephony configuration of the exchange. BT in their 'wisdom' many years back elected not to pass on the full International number and substituted 'International' in its place. 'Withheld' and 'unavailable' are similar instances of the same technique of handling (obfuscating!) presentation numbers. There are - or were at the time - good reasons for doing things that way. The actual configuration changes are relatively straight forward, but have to be built in with other changes / fixes / updates for each exchange - and then scheduled for implementation. So it will take while to become the norm across ALL BT exchanges.
Maurice
- Home Phone
