Caller Display
- Home Phone
- Caller Display
Caller Display
05-11-2011 2:29 PM
Will be transferring to PN on Monday for Phone & Broadband package with caller display included. I Understand that the caller display has to be activated via PN website. where will I find information on how to do that ?
We are born into history and history is born into us.
Message 1 of 5
(1,042 Views)
4 REPLIES 4
Re: Caller Display
05-11-2011 2:42 PM
https://portal.plus.net/support/phone/call_features.shtml#addRemove
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 5
(310 Views)
Re: Caller Display
05-11-2011 2:46 PM
Peter,
Thanks for that !
Thanks for that !
Message 3 of 5
(310 Views)
Re: Caller Display
05-11-2011 4:19 PM
I recently transferred my phone to Plusnet and opted for anytime calls and caller display. I found the caller display worked from the start and I didn't have to activate it so may be worth checking before doing anything. I had caller display with previous supplier BT.
If you want voicemail (1571) it is free but you'll need to add it via the Telephone Control Panel before you can use it.
Message 4 of 5
(310 Views)
Re: Caller Display
06-11-2011 5:36 PM
Thats handy to know I currently have caller display with my BT line so will check it out following my phone being transferred to Plusnet tomorrow
Message 5 of 5
(311 Views)
