Caller Display not working
Tina71
Hi, just moved to Plusnet from BT and the caller display isn't working. I've called *# number and it says will be displayed but isn't. Got a BT8600 so should have. any ideas.
6 REPLIES 6
Fixes: 1,602
Re: Caller Display not working
Welcome to the community forums and to Plusnet @Tina71
I'm sorry to hear caller display isn't working
I can see it's showing as active on your line, so I'm going to try removing the feature and then re-adding it.
It should be removed overnight and we'll let you know tomorrow when it's re-added.
Fixes: 1,602
We've re-enabled caller display on your line.
Can you confirm it's working?
Tina71
Hiya,
Just got home and tried it, just says incoming call when rings (and no number on other calls that have rung)
T
Fixes: 1,602
Cheers for getting back to us. I've raised a fault to our suppliers now to further investigate.
We'll be in touch when we've got more info.
Tina71
This is now working, thank you.
Fixes: 1,602
I'm glad to hear that!
Please let us know if you need any further help.
