Caller Display not activated
- Home Phone
- Caller Display not activated
30-07-2017 10:29 AM
I've had my plusnet for over 10 days caller display is not active. The control panel says it is awaiting activation . I am being charged for it. How can this be resolved
Message 1 of 2
(551 Views)
1 REPLY 1
Re: Caller Display not activated
31-07-2017 12:38 PM
It looks like caller ID wasn't active on the back end systems. I've just done that for you now, and it should start working within the next few hours. I've also raised a task [516017] internally to fix the home phone control panel for you.
I've also removed voicemail from the line [this should take a few hours too] as per your thread over here
I hope this helps.
Message 2 of 2
(504 Views)
- Home Phone
