Caller Display not activated
H_Singh
I switched from BT to Plusnet on 9 September but my Caller Display isn't working, the Phone Control Panel shows it as activated but dialling *#234# says the service is not available.
6 REPLIES 6
Chris
Legend
Fixes: 169
Re: Caller Display not activated
It's showing as on your account both on our side and our suppliers system, are you still having issues with this?
H_Singh
Hello, yes it still isn't working and the message on *#234# is the same. Caller ID was working on my phones when I was with BT and when I've been with Plusnet in the past.
HarryB
Fixes: 256
I'll try removing the call feature and re-adding it to your line as that quite often fixes this.
I'll let you know when this has completed.
 Harry Beesley
HarryB
Fixes: 256
Those orders are complete now. Could you let us know if you're still having problems with the caller display from now.
Thanks.
 Harry Beesley
H_Singh
That fixed it, thanks Harry.
HarryB
Fixes: 256
Glad to hear that's fixed now. Thanks for letting us know.
 Harry Beesley
