Call protect
adrian001
Call protect
My plusnet call protect feature doesn't work.
Any ideas?
6 REPLIES 6
BrightonRock
Fixes: 8
Re: Call protect
Can you be a bit more specific please? Is it not active? Or not blocking some calls? If so, which ones? Or is there some other problem?
adrian001
Re: Call protect
As I stated in my post, it is not working. Call protect shows as active and is ticked. However when I dial 1572, I get a message saying that this service is not connected.
198kHz
Fixes: 41
Re: Call protect
@adrian001 I believe it can take up to 24 hours to kick in after application - has it been that long?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
adrian001
Re: Call protect
Yes I understand that, but this was added to the account months ago and has not worked since.
Adrian
198kHz
Fixes: 41
Re: Call protect
OK. Unless you get lucky on the phone or TwitBook, it's a case of waiting for a Help Team member to see this thread and respond.
BrightonRock
Fixes: 8
Re: Call protect
@adrian001
I'm afraid @198kHz  analysis is probably right that this is going to need intervention from a PlusNet person.
There is a slim chance, and it probably can't make your position any worse, but you could try turning off Call Protect and then turning it back on again. I think it has been known to work! It really depends what the underlying problem is.
