Call protect not working
LilyF
I recently moved my phone line from BT to plusnet. I had call protect with BT and it worked very well, but since I've transferred over I get the message that the 'service is unavailable' when I try to call 1572. On my control panel it's ticked as green. Could this feature be turned on? Have I lost all the numbers I'd added with BT?
Between billing me wrongly and having to chase a repayment, nightmare in trying to get through to phone support, and now basic features not working I'm really regretting moving my phone line.
4 REPLIES 4
TheMightyAJ
Fixes: 126
Re: Call protect not working
Hi @LilyF,
I'm sorry to hear that you have experienced these issues. I can see that the Call Protect feature appears to be up and running from our side and so I would ask whether or not you've been able to see if the feature would work with another handset?
 Alex H
LilyF
Hi AJ
I can confirm it doesn't work from my other phone either, which is a corded handset.
To be accurate, the message I'm getting is "The service can not be connected."
Lily
MatthewWheeler
Fixes: 478
Thanks for the info.
Upon further investigation it looks like it isn't active on our suppliers side.
I've placed a order to add this and it should be up and running within a hour.
 Matthew Wheeler
LilyF
Thank you Matthew. Confirmed working now.
