Call charges
- Home Phone
- Call charges
Call charges
12-11-2012 2:08 PM
I've found this tariff page which is good but what I need to know, too, is what charge band a number, say, 0871 80x xxxx.... comes under.
Is this info on the portal somewhere?
Thanks.
Edit: It's Ok, found them here
Forum Moderator and Customer
Re: Call charges`
12-11-2012 2:12 PM
Hope that helps.
Re: Call charges`
12-11-2012 2:16 PM
BT has a page with the relevant codes matched to their number then just need to then search for that code in the first link.
Now if only there was an easier way to combine the two
Edit: Opps yes, PN's own page has a link to the special codes and much easier to read that BT's in my opinion. Don't know how I missed it, though, it's at the top of the bloody page
Edit2: Actually, I take my last comment back. the second link only gives the price once you know the code. I would still need to know the relevant code that matched the number - so back to the BT list!
Re: Call charges
19-11-2012 10:59 AM
Re: Call charges
19-11-2012 12:30 PM
I think I was referring to the link on the tariff page called Essential Home Phone Tariff.
Re: Call charges
19-11-2012 1:09 PM
