Call barring PIN Home phone
- Home Phone
- Call barring PIN Home phone
26-08-2022 5:46 PM
My PIN no longer works. How can I check and change it? thanks.
Message 1 of 2
(711 Views)
1 REPLY 1
Re: Call barring PIN Home phone
02-09-2022 10:59 AM
I've had a look with a colleague and I'm afraid we can't see a way for you to check or change the PIN.
If you however remove then re-add it from your account by going Here you'll be prompted to set a new one.
Message 2 of 2
(635 Views)
- Home Phone
