Call Protect cannot be connected
FIXED- Subscribe to RSS Feed
- Home Phone
- Call Protect cannot be connected
Re: Call Protect cannot be connected
31-07-2020 8:20 PM
Hi @olliebean Appears to be getting somewhere now.🙂
31-07-2020 9:48 PM
Everything is deactivated now, without me having got around to raising a ticket (I don't know whether @Tibzor's intervention had anything to do with that or not). For the moment, I shall wait and see what happens rather than attempt to do anything more myself.
31-07-2020 10:15 PM
Hi @olliebean
Yes it was the intervention of @Tibzor and if you wait 24hrs go to your account, activate Call Protect and see what happens. If you still have a problem report it back here.
31-07-2020 10:15 PM
@olliebean wrote:
Everything is deactivated now, without me having got around to raising a ticket...
Except for a few specialised issues, the facility for customers to raise tickets was withdrawn several years ago.
@Tibzor 's intervention is undoubtedly the reason for signs of progress, and s/he will have raised a ticket, which you can view by logging in here: https://www.plus.net/wizard/?p=search
Hope it goes well. 🤞
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
31-07-2020 10:35 PM
Hello, it was actually I that deactivated the call features on your account so they could be re-added. Sorry I should’ve posted earlier on.
After @Tibzor’s intervention of adding them directly into the supplier systems has completed, we’ll fix your account up next week so you’ll be able to manage the call features yourself.
01-08-2020 8:15 AM
Hi @Gandalf
Wondered what had happened to your reply, thought you may be on Hols.Thanks for helping out.
01-08-2020 9:51 AM
01-08-2020 9:58 AM
Hi @olliebean
Glad to hear all is working apart from showing on your account, I am sure this will rectify next week sometime You may need the attached to help you further
03-08-2020 8:51 AM
Awesome, no problem @olliebean your account should be sorted for you now.
03-08-2020 8:59 AM
Just confirming it's all showing correctly on the website now as well.
08-08-2020 6:54 PM
@Gandalf , I have had Plusnet call protect for some time and recently (like a week or so ago) I needed to blacklist one number which was becoming a nuisance, but at the time of activating call protect I was not given the number 1572 to dial to block (or redirect) the number and therefore I had to make a call to plusnet customer service which took a long time to get through - to be told to dial 1572 and then proceed from there.
My concern is if I need to check which numbers I have "redirected" using 1572, how do I go about it. Is there a procedure somewhere on plusnet website to follow? Please do enlighten us the (poor and struggling) customers.
Thank you and I hope to hear soon from you.
Many regards,
Chandu.
08-08-2020 9:06 PM
Hi @chandu
There is a call protect table in other replies giving details of what to do. If you cannot find it let me know and I will re-post it once again.
09-08-2020 4:58 PM
Sorry. unable to find the table you have mentioned. It is definitely not on this thread. So, where is it? Please help. Thanks in advance.
Regards,
Chandu.
09-08-2020 5:03 PM - edited 09-08-2020 5:06 PM
Is it this one?
That's what came up on a search for "Plusnet call protect table". The comment at the bottom, though, doesn't fill one with confidence:
"This table has been compiled using the instructions and by listening to the voice instructions on 1572. There may be errors and are certainly omissions."
09-08-2020 5:05 PM
@chandu Look at message 23 in this post
- Home Phone
