Call Protect cannot be connected
olliebean
I have recently added the Call Protect feature to my account, and it is showing as "Currently active" on the Call Features page of my account. But when I dial 1572, I get a message saying "The service cannot be connected." Is there anything else I need to do to get it working?
31 REPLIES 31
mort7890
Fixes: 4
Re: Call Protect cannot be connected
How recent as I think it takes around 24hrs to fully activate
olliebean
It was a few days ago. On the day I added it, it was showing as something like "in progress," but now it is showing as "Currently active" so it should be working, unless I'm missing another step.
Also - probably related - if I dial 1571, I get a message saying "This line doesn't have a call answering service," although Voicemail is also showing as "Currently active" on my account. (I think it was automatically added when I added Call Protect.)
mort7890
Fixes: 4
Have you raised a ticket as a fault
olliebean
Not yet, as I don't need it urgently and I've seen people get similar problems solved by posting here. If I get no joy here, I'll raise a ticket.
mort7890
Fixes: 4
Try de-activating it then after a while re-activating it. See if that works, you should get e-mails to confirm.
olliebean
OK, I'll try that. I don't think I got any email to confirm activation the first time.
mort7890
Fixes: 4
If you have not got an e-mail then more than likely it was not activated. I have just looked at my e-mails as I had to reset the call protect due to filling the blocked calls up and received e-mail confirmation for removal then re-activation.
olliebean
Having checked my emails, there was definitely something odd going on because I actually had an email confirming deactivation of Voicemail, even though it hadn't previously been active, and according to the website it went from inactive to active. I didn't receive any emails at all about Call Protect.
Just waiting now for everything to be deactivated so I can start again tomorrow.
jwsg
When I tried to add Call Protect I got emails saying
Voicemail would be removed
Voicemail has been removed
Voicemail and Call protect will be removed
Voicemail and Call protect has been removed
I then tried to add Call Protect again and received emails
Call protect will be added
Call protect has been added
Then 1572 began to work
mort7890
Fixes: 4
If you have received emails regarding de-activation you will probably not have to wait overnight. Just try activation again to see if you receive confirmation then see if 1572 works
olliebean
I had the email about deactivation when I tried to activate. I haven't had any more yet, and I can't make any more changes at the moment since the website says "You cannot make any changes to your account while there is a phone order in progress." So I guess I have to wait until the deactivation is confirmed before trying to activate again.
olliebean
So two days after deactivating the Call Protect and Voicemail services on the website, I've received no email notifications of anything, and the website still says "Awaiting removal" next to those services and won't let me make any other changes in the meantime. It definitely seems like there's a problem, and I guess I'm going to have to raise a ticket after all.
mort7890
Fixes: 4
Perhaps you may find @Gandalf or another member of staff will look into it for you
Tibzor
Fixes: 25
Hey @olliebean
Sorry to hear about this ongoing problem, I have now manually placed orders in Openreach systems, please allow up to 24h and get back here/send me PM if that won't work (Please check both numbers and ignore status on member centre as orders were created directly in OR systems). Order was not automatically rejected so it is good indicator. I won't be working during weekend but if you will need further assistance I will be back on Monday.
