Call Protect :International Number Blocking Problem
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Call Protect :International Number Blocking Pr...
18-05-2018 5:03 PM - edited 18-05-2018 5:04 PM
Hi - can anybody help me with this problem. I blocked all International Calls on Call Protect but then found out my daughter, living in the Channel Islands, had been blocked as an International number.
I took the International call block off but we are getting so many of them - they drive us mad!
Is there any option to keep the block on International calls but to 'whitelist' (exclude her number from the block?)
I have been through the options on 1572 but can't understand most of them so don't know whether they include this option.
Would be immensely grateful for any reply
Fixed! Go to the fix.
18-05-2018 5:18 PM
Hi @LizMac42,
I believe if you dial 1572 and then select option 4 you should get an option for VIP List.
If you put the block in place against international calls and then add your daughters number to the VIP List, this should override the block for her number specifically.
More information on this can be found here: https://www.plus.net/help/phone/call-features/
I hope this helps.
Re: Call Protect :International Number Blocking Problem
18-05-2018 6:25 PM
Thanks ++ for this Harry - I have done what you suggested and let my daughter know so when she phones or messages me I will let you know if it works.
20-05-2018 2:54 PM
Thanks again Harry - IT WORKED - my daughter can ring me and all those annoying Internationals have stopped - Bliss!
23-05-2018 12:35 PM
- Home Phone
