Call Protect: Format of VIP numbers
- Home Phone
- Call Protect: Format of VIP numbers
21-11-2017 1:12 PM
I've turned on blocking of international numbers and want to enter some VIP exceptions. One example is for a Gothenberg number in Sweden where I initially entered:
46 31 XXXXXX
However, the system said that it only accepts numbers starting with a zero. So do I just add 0 to the above or two 0's or what?
Does this also apply to Swedish mobile numbers?
Re: Call Protect: Format of VIP numbers
21-11-2017 2:06 PM
Would assume you add the two 0's to recognise the incoming number as you have to enter the area code with UK.
21-11-2017 2:39 PM
I'd agree with mort - when I get a call from Ireland the caller display says 00353xxxxxxxx, the same format as I would use to call them.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
- Home Phone
