Call Guardian
kerz2201
Call Guardian
Hi, have just moved to Plusnet and cannot get Call Guardian to work.  Have asked for the voicemail service to be de-activated and this appears to be done but Call Guardian still not working.  Can anyone help please?  Many thanks.
4 REPLIES 4
southerner
Re: Call Guardian
Do you have the Caller ID service? Only that's the main thing Call Guardian needs to work.
kerz2201
Re: Call Guardian
Hi, thanks very much for your reply.  Yes I do and that appears to be working ok.  Don't know what else I can do to fix this.
southerner
Re: Call Guardian
Which part of the Call Guardian functionality is not working for you?
kerz2201
Re: Call Guardian
Hi, I have just retested from my mobile and blocked the number and this worked ok.  Many thanks for your replies.
