Call Divert
- Home Phone
- Re: Call Divert
Call Divert
01-07-2018 6:45 AM
Hi Everyone,
I have call divert set up as a package on my home line. I have read the instructions on activating and deactivating call divert, but I need to do if I know if I can enable or disable it remotely. If I am not at home I would like the facility to knock it on or off from my mobile.
Does anyone have any ideas?
Thanks,
Ian
Re: Call Divert
01-07-2018 7:56 AM
Ok I checked another thread, so:
Have a look at the first post in this link, which may do what you want.
Re: Call Divert
01-07-2018 8:05 AM
Hi Alex,
That is the page I read, regarding controlling it from your land line it's self. It doesn't cover remote activation or deactivation, which was what my question was about.
Thanks for trying though.
Ian
Re: Call Divert
01-07-2018 8:08 AM
Ok sorry if I've confused everything here, but I would assume with the phone control panel you can login remotely?
Re: Call Divert
01-07-2018 8:13 AM
Nope, just buy the feature. That's fine, I purchased it and it's activated as a feature, but it doesn't allow you to control the actual enable or disable, or change the destination number remotely.
For example, if my mobile battery was going, and I needed to change the divert to a different number, or just switch divert off entirely, I would like to do that from a line other than my fixed landline. I wouldn't be using call divert if I was at home, so I'd be wanting to access it remotely to change the settings.
Re: Call Divert
01-07-2018 8:20 AM
Re: Call Divert
01-07-2018 10:35 AM - edited 01-07-2018 10:37 AM
That's a facility which is part of 'Featureline', a BT business product which is essentially a 'virtual PBX'.
The OP's requirement would be met with Smart Divert, again a BT business product, applicable to single lines.
Perhaps a PN staffer could tell us whether this would be available to the OP if he were to change his line from 'Residential' to 'Business'?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Call Divert
02-07-2018 11:48 AM
Welcome to the community forums @bonham01.
I'm afraid call divert can only be managed from your phone (Unless it's added as part of a fault report and we're specifying the number to divert to on your behalf)
Apologies for any inconvenience this causes.
@198kHz, Our business call package call features are the same as our residential call features, with the exception of call protect/choose to refuse, which are not offered on business lines.
Re: Call Divert
02-07-2018 11:53 AM
@HarryB Thanks for info.
Re: Call Divert
02-07-2018 4:39 PM
One would think that remote call diversion was a basic requirement for all users (not just businesses) yet AFAIK no supplier offers it as even a priced option for residential customers.
It would be a Unique Selling Point for any supplier that was able to implement it.
Re: Call Divert
03-07-2018 10:26 PM
Erm, so I need to be AT HOME to divert to another number that is NOT at my home?
We work this logic how?
Re: Call Divert
03-07-2018 10:36 PM
@bonham01 As far as I'm aware that's always been the case with any CP/ISP, unless you're a BT Business customer with deep pockets -
in which case Smart Divert will be available as mentioned in Message#7.
