Call Divert *61
Shuff
Call Divert *61
I have Call Divert set up on my line. Setting up using *21*number to divert to# works just fine.
According to the instructions, using *61*number to divert to# should send the call to the diverted number if it’s not answered after 15 seconds. What actually happens is that the caller immediately gets a message saying ‘this call is being diverted’ while my phone does NOT ring at all.
What’s the problem?
9 REPLIES 9
adamwalker
Fixes: 221
Re: Call Divert *61
I'd try setting that up again, it could be that the wrong number was entered by mistake when setting up the diversion.
Please give it a try and let us know if that's still a problem.
 Adam Walker
Shuff
Re: Call Divert *61
Hi there.
The number is set up correctly *61*(number to divert to)#
When a caller calls my number, my phone does not ring for 15 seconds.
The caller immediately hears a calls to this number are being diverted message (for 15 seconds), after that they hear the ringing tone as the call is diverted to the ‘number to divert to’.
Fixes: 1,600
Re: Call Divert *61
Thanks for getting back to us.
That's odd, does this happen when anyone tries to call you regardless landline or mobile?
Are you also able to try setting it up using a different phone number just to narrow things down a bit?
Shuff
Re: Call Divert *61
I’ve diverted to a landline number instead of my mobile - same result.
I’ve got people to call me from landline and mobile - same result.
My landline doesn’t ring for 15/seconds and the caller gets a ‘calls to this number are being diverted’ message for 15 seconds.
Feel free to arrange a test call.
Fixes: 1,600
Re: Call Divert *61
Thanks for the detail.
To try to resolve the issue are you happy for us to try removing call divert completely then re-adding it?
Shuff
Re: Call Divert *61
Hi there.
I'm happy for you to try that but please keep me updated.
Thanks.
Fixes: 1,600
Re: Call Divert *61
Thanks, I've placed an order to remove the call feature which has completed and I've got another order in place to re-add it which should complete within the hour. Let us know how it goes.
Shuff
Re: Call Divert *61
Thank you very much.
That seems to have solved the problem. It’s working fine now.
Fixes: 1,600
Re: Call Divert *61
Glad to hear that! Thumbs_Up
Let us know if you need any further assistance.
