CSV dates are in US format instead of UK
petlon
Since the new phone billing system started in September I have discovered that the "View Billed Calls - Export CSV" file shows the dates of calls in US format (ie MM/DD/YY) instead of UK (DD/MM/YY) that should be shown and was in the previous system.  Could the IT guys please change the CSV export to UK date format.  Curiously the Phone bill pdf does show the dates in UK format so maybe a little tweak required for the CSV...?
Thanks in advance
Petlon
2 REPLIES 2
pjmarsh
Fixes: 19
Re: CSV dates are in US format instead of UK
That seems odd.  It's exporting them correctly for me, though I had to go back a couple of months to find come calls!
pjmarsh
Fixes: 19
Sorry, ignore that.  Looking on a different account and I can see what you mean.
