CLI not working
Rushncrushem
CLI not working
Hi
My CLI has not been working since I had the phone service installed. Never really noticed until last week.
I have tried the usual method of confirming the feature is active using the 3 available *234# commands.
The CLI feature worked with my previous supplier so assume phone is compatible, and have also tried in test socket which was a pain but still the same result.
Take your time to have look it's a CLI problem so not mega important, I have a "end call" button for PPI calls  Grin
Cheers  Wink
5 REPLIES 5
Mustrum
Fixes: 76
Re: CLI not working
With PlusNet CLI is a chargeable option, controlled via thehttp://=https://portal.plus.net/plustalk/index.php?page=wlr_add_call_features Home Phone Control Pan... have you switched it on?
jelv
Fixes: 10
Re: CLI not working
It must be, otherwise he couldn't have posted
Quote from: Rushncrushem
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MatthewWheeler
Fixes: 478
Re: CLI not working
It looks like it wasn't added as part of the transfer.
I've added it now and it should be working shortly.
 Matthew Wheeler
Rushncrushem
Re: CLI not working
Thanks for looking at this Matthew, It's working fine now.
Cheers
MatthewWheeler
Fixes: 478
Re: CLI not working
Glad to hear it's all working.
 Matthew Wheeler
