Buzz on the line
forumtalker
Buzz on the line
Good afternoon
We have had a buzz on the line for a few days,  The phone is plugged into the main socket, one of the newer types with a built in router socket.  It's on incoming and outgoing calls.  Can you do some line tests?
regards
2 REPLIES 2
Mads
Fixes: 79
Re: Buzz on the line
Hello @forumtalker,
Thanks for getting in touch.
I am sorry to read you are having trouble with your phone line and have created a ticket on the account with my findings from the line test. You can view it here.
Fixes: 398
Edit
Deleted as Mads has already addressed it.
