Broadband phone problems
- Home Phone
- Broadband phone problems
08-08-2007 6:47 AM
Does anyone else find their broadband phone cutting out part way through calls? I use the Speedtouch 316 router and have plugged a normal cordless phone into its phone port. I did have it working OK (apart from calls regularly cutting out after only 1 minute) but I had to reset my router and now all I get is a continuous unavailable tone. I've entered the server and proxy details and all the right port numbers, can anyone suggest what might be wrong?
Andrea
http://www.allaboutoffice.co.uk
Andrea
Message 1 of 4
(5,670 Views)
3 REPLIES 3
Re: Broadband phone problems
08-08-2007 9:29 AM
Have you tried using a software phone to see if the same issue is apparent on there?
Message 2 of 4
(1,481 Views)
19-08-2007 7:53 PM
I don't sit near my PC at the times when someone might ring me. My mum rang me today and we were only able to speak for about a minute before it cut out, that was using a plain BT wired phone plugged into the Speedtouch router.
I have bought a differet ATA VOIP router box as well but I haven't been able to get it to work, it asks for things like service name and I can't suss out whether I've got the right settings.
Andrea Jones
Andrea Jones
Message 3 of 4
(1,481 Views)
20-08-2007 4:49 PM
Message 4 of 4
(1,481 Views)
