Broadband light flashing, no internet light on at all & no dial tone on phone
- Home Phone
- Broadband light flashing, no internet light on at ...
07-12-2017 9:31 PM
Re: Broadband light flashing, no internet light on at all & no dial tone on phone
07-12-2017 9:47 PM
If you have no dial tone then you will not get any broadband. Your first action should be to chase the phone fault as that tends to be treated with higher priority. Once that's fixed you may find that broadband works without further intervention.
07-12-2017 10:15 PM
07-12-2017 10:22 PM
I think the support lines are now closed, but if PlusNet is your phone provider, then yes, chase them up.
You may be lucky and get one of the helpful staff members spot your post, but it will likely to be quicker to give them a call.
07-12-2017 10:46 PM
08-12-2017 12:27 AM
08-12-2017 8:59 AM
08-12-2017 12:46 PM
A tip for you, now you have Gandalf's (a member of PN' staff and a really helpful guy) attention reply to him as follows using '@':
As the OP has no dial tone and hence no phone or broadband there is no way to log in henceas far as I can see the troubleshooter cannot work. Am I correct in suggesting that th OP needs to report a phone fault or can you check this out from you end?
08-12-2017 1:24 PM
Iv been online chatting to a couple of guys, everything looks fine from your end it seems, so i have an engineer coming out tuesday 12th. Any help sooner would really be appreciated
08-12-2017 3:19 PM
When I recommended that you reply to Gandalf I didn't realise you had already contacted PN and they had already run the tests I had in mind. Have PN talked you through basic tests at your end, for example:
Have you tried plugging a known working wired phone into the test socket, that's the one behind the removable front socket of the master socket? This will remove all your internal wiring. Do not use the filter for this test
12-12-2017 1:51 PM
12-12-2017 4:06 PM
13-12-2017 10:38 AM
- Home Phone
