Block unanswered calls
FrintonFogey
I have recently been receiving many 'international calls' and when answered they hang up with no message. I have been told that these are computer dialling robots that generate random phone numbers and if answered pass the number on as a genuine number to suspicious gangs! I already use Call Protect but this only allows you to divert answered calls, so, is it possible to enter numbers into the system without answering them first?
3 REPLIES 3
198kHz
Fixes: 36
Re: Block unanswered calls
There are several options to block by call type eg 'International'.
PDF of instructions here .
If you want the best seat in the house, move the cat
FTTC 40/10   Billion 8800NL
BT technician (Retired)
FrintonFogey
Many thanks for instructions, works perfectly  - I didn't know there were so many options!
198kHz
Fixes: 36
@FrintonFogey
Thanks for update. Good to hear that it's working well.  🙂
