Bill information?
Luzern
Fixes: 9
Bill information?
How informative is the information on the bills received? An example from Plusnet could be useful to compare with my current relephony supplier.
6 REPLIES 6
Fixes: 160
Re: Bill information?
What are you looking for? A full list of calls is available via the portal (can be down loaded) whereas the bill itself just has each charge item listed as a total figure.
Fixes: 1,600
Here's a screenshot of what your itemised bill would look like:
When you click on View Details you'll see something similar to:
As this is taken from my own account, and I don't have a home phone plugged in, the call summary is a bit empty.
But I hope this helps you.
198kHz
Fixes: 41
The main reason for changing telephony supplier from BT was the clarity of the billing.
The £2·50 discount on broadband was welcome too.  Smiley
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Luzern
Fixes: 9
@Gandalf Thanks for that
@198kHz  Yes, it does appear more informative than BT, and as you say it'd cost £2.50 less a month. I recall that sometime past the billing was claimed to be not always accurate. I hope not now. The things that turned me off before were Caller ID charge and dealing with line faults. only the latter outstands, but is perhaps less a concern to what it was.
@Townman I like to keep some form of analysis to keep myself on correct package.
Fixes: 1,600
No problems at all.
If you do decide to go ahead, please feel free to let us know over here if you do encounter any problems at all.
Fixes: 160
The real upside of having phone and broadband with the same provider is that when there are issues, the problem cannot be passed between ... it’s a phone problem ... it’s an internet problem.
