Battery fault
- Home Phone
- Battery fault
Battery fault
17-10-2015 6:29 AM
We have loud clicking ,voice echo ,constant ringing of the phone , no caller display , we can not use the phone to make calls, the FTTC seams OK at the moment
I have reported this to plusnet after a 3/4 hour wait on the phone to be told yes you have a problem ,it's a battery fault and will be repaired by Tuesday 20th , surely a 4 day wait is not acceptable can this be processed faster please
This is also affecting my neighbours phones
Cheers
Chris
Cheers
Chris
Message 1 of 3
(995 Views)
2 REPLIES 2
Re: Battery fault
18-10-2015 3:28 PM
All back to normal now ,engineer has been
Message 2 of 3
(207 Views)
Re: Battery fault
19-10-2015 9:30 AM
Sorry this didn't get picked up over the weekend. Glad it's resolved for you.
Matty
Matty
Message 3 of 3
(207 Views)
