BT cuts the cost of calling 0845 and 0870 to zero for many of its customers
- Home Phone
- BT cuts the cost of calling 0845 and 0870 to zero ...
Re: BT cuts the cost of calling 0845 and 0870 to zero for many of its customers
09-01-2009 10:17 AM
09-01-2009 11:00 AM
09-01-2009 11:07 AM
09-01-2009 11:08 AM
I'd much prefer PN to make these calls inclusive - even if they had to slightly rise other chargeable calls.
As others have said - so many of us have to phone companies that use these numbers, and hang onto the line for 10, 15 20 minutes , and have no alternative if saynoto0870 can't help.
as someone over on another forum highlighted - very many people regard these 0870, 0871 & 0845 numbers as a real irritation, and it was a clever marketing move by BT Retail.
But what I think is really needed is for OFCOM to sort out the whole mess of premium rate numbers etc etc.
09-01-2009 11:14 AM
I posted this link a bit further up the thread.
Ofcom are looking at 0870 charging, this quote being quite pertinent:
(my bold)
Quote Today’s consultation proposes that all calls to 0870 numbers should normally cost no more than calls to geographic numbers (01 or 02 numbers) and that 0870 calls should be included in communications providers’ call packages price plans on the same basis as geographic calls. This may significantly reduce the cost of calling these numbers.
It makes no mention of 0845 though.
09-01-2009 11:19 AM
09-01-2009 11:46 AM
The press release from BT (also linked further up) didn't mention any calls other than 0845 and 0870 and I think there would have been a bit more "trumpet blowing" about it if 0871, 0844, etc. had been included!
09-01-2009 5:28 PM
Quote from: Jameseh Guys - To be clear, this is something being offered by BT Retail.
Ok, so why is it that when BT trades as "BT" (through BT Retail) they provide free 0845/0870 numbers, but when they trade as "plusnet" they don't?
plusnet is a BT plc company, so surely the announcement by BT plc should apply to all the retail subsidiaries?
Jon
09-01-2009 5:31 PM
BT Retail pay Openreach for the telephone services, just as we do.
BT Retail are making the price changes on their telephone product, whereas OpenReach are not.
Think of it as a product rather than a brand.
09-01-2009 8:05 PM
BT rental is £12.91 pm for evening and w/e calls, PN is £9.75 pm. Calls to mobiles (except 3) are also cheaper with PN.
All other calls 0844/0871/090 etc are the same as BT. So just comparing the rental, if you spend more than £3.16 per month on calls to 0845/0870 then you might now be better of with BT.
I avoid 0845/0870 calls like the plague. Unless there is no alternative I don't do business with companies that only have 0845/0870 numbers.
At the end of the day each user has to look at their own calling pattern and see which Telephone provider's package suits them best.
Well I'm happy with PN's as it is thanks.
09-01-2009 10:01 PM
Quote So just comparing the rental, if you spend more than £3.16 per month on calls to 0845/0870 then you might now be better of with BT.
...and that assumes you make the calls in the evening or at the weekend as, on the Evenings and Weekends package, 0845 and 0870 will be charged weekday daytime. You'd need to take BT's "Unlimited Anytime" package to get 0845/0870 "free" all day, every day.
Also, from this page on BT's updated site:
Quote †Free calls to 0845 and 0870 numbers
Availability of free 0845 and 0870 calls of up to 60 minutes duration (excluding indirect access numbers and dial-up internet access) dependent on residential BT Calling Plan: weekends only (with the Unlimited Weekend Plan), evening & weekends (with the Unlimited Evening & Weekend Plan), or any time (with the Unlimited Anytime Plan). Fair use policy applies – max. 1,000 mins or 150 calls a month. If either of these limits on free calls is exceeded, BT will charge for these calls until further notice.
This FAQ page has more info. It also answers the 0871/0844 question:
(my bold)
Quote Please note that we're still going to charge for calls to 0845 and 0870 numbers used for dial-up Internet or indirect access. We're also still charging for calls to numbers starting with 0871 and 0844.
09-01-2009 10:42 PM
Quote from: Anotherone BT rental is £12.91 pm for evening and w/e calls, PN is £9.75 pm. Calls to mobiles (except 3) are also cheaper with PN.
My BT line rental is 10.50.
With the anytime package PN mobile calls are more expensive during the daytime.
10-01-2009 12:12 AM
10-01-2009 2:14 AM
Since when did PN's 9.54ppm daytime rate come to be more expensive than BT's 12.234 ppm daytime rate for calls on Unlimited W/E plan (was option1) and Unlimited Evening & W/E plan (was option 2), and UNLESS you are on the Anytime plan (was option3) when mobile saver is inclusive otherwise an extra £1.47 per month, with this the daytime rates may be cheaper but the evening rates are more expensive! In anycase my comparison was not with 12month contracts or Anytime plans, and by the way have you seen the BT penalty get out charges, unless you notify them in that short interval in month 12 of any period!!
10-01-2009 2:36 AM
- Home Phone
