BT Diverse X10 lost PIN
Wuz
I have a couple of these and the one on the base has died. I want to reprogram the remaining one to work on the base.
However, I changed the PIN from 0000 years ago and despite many attempts I can't remember the PIN!
The manual says if this happens I should contact the BT Helpline on 08702 403180. However I am now with Plusnet so I don't expect they would want to help. I was with BT when I bought the phones.
Anybody know how to reset the PIN to 0000? I  pressed S for 10 seconds but that has just wiped the directories!
Thanks in advance for any help.
Wuz
6 REPLIES 6
w23
Fixes: 4
Re: BT Diverse X10 lost PIN
I'd think the helpline is for anyone who has purchased a BT telephone, not just BT landline/internet customers, I'd go ahead and ring it (just check what your charges are for 08702 numbers are).
Call me 'w23'
198kHz
Fixes: 40
I would agree with w23. However, on BT's website - http://bt.custhelp.com/app/answers/detail/a_id/11884/c/1243,1899,1918
Product helpdesk information
BT does not offer helpdesk support for this product.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Projjer
On some other makes of Dect bases they can be reset to factory default by
1 .  Remove the power lead from the base
2 . Press and hold the "Page" button
3  . Plug the power cord back into the base.
4 . Continue to keep the "Page" button pressed for 10 seconds.
HTH
Wuz
Thanks Projjer,
Resetting worked, although I had to do it a few times. I had given up and tried again after a couple of weeks, when I was about to chuck it out, and it worked! Goodness knows why it didn't work the first time!
Sorry I didn't get back earlier.
Regards,
Wuz
Projjer
@Wuz
Thanks for the update, pleased to see it worked. Smiley
I suspect that a number of manufacturers use the same system chips which are reset in the same manner.
Cheers
mabs123
Also worked perfectly on my old BT Diverse 2016 base station. I too had forgotten the pin that I had changed many years ago. Can now go ahead and buy replacement handset. Thanks for the tip, it just shows how useful this community can be.
