BT Diverse X10 lost PIN
- Home Phone
- Re: BT Diverse X10 lost PIN
20-03-2015 8:58 AM
However, I changed the PIN from 0000 years ago and despite many attempts I can't remember the PIN!
The manual says if this happens I should contact the BT Helpline on 08702 403180. However I am now with Plusnet so I don't expect they would want to help. I was with BT when I bought the phones.
Anybody know how to reset the PIN to 0000? I pressed S for 10 seconds but that has just wiped the directories!
Thanks in advance for any help.
Wuz
20-03-2015 9:23 AM
20-03-2015 9:44 AM
Quote Product helpdesk information
BT does not offer helpdesk support for this product.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
22-03-2015 12:32 AM
1 . Remove the power lead from the base
2 . Press and hold the "Page" button
3 . Plug the power cord back into the base.
4 . Continue to keep the "Page" button pressed for 10 seconds.
HTH
06-05-2015 8:38 AM
Resetting worked, although I had to do it a few times. I had given up and tried again after a couple of weeks, when I was about to chuck it out, and it worked! Goodness knows why it didn't work the first time!
Sorry I didn't get back earlier.
Regards,
Wuz
07-05-2015 4:21 AM
Thanks for the update, pleased to see it worked.
I suspect that a number of manufacturers use the same system chips which are reset in the same manner.
Cheers
05-01-2018 2:31 PM
Also worked perfectly on my old BT Diverse 2016 base station. I too had forgotten the pin that I had changed many years ago. Can now go ahead and buy replacement handset. Thanks for the tip, it just shows how useful this community can be.
- Home Phone
