Are fax's chargeable?
- Home Phone
- Re: Are fax's chargeable?
28-10-2013 10:31 PM
Hi
I have the Talk Anytime phone package with my fibre broadband & have a question.
The fax number is the same area code as my landline so would it be free or would it be chargeable as technical it's dialling up on a modem?
Cheers in advance
Lee
Cheers in advance
Lee
Message 1 of 7
(1,726 Views)
6 REPLIES 6
28-10-2013 11:33 PM
Faxes are no different to normal phone calls and are charged according to the destination number. If it's on the same area code it's almost certainly a local rate call which may be included in your calls package.
Message 2 of 7
(711 Views)
28-10-2013 11:34 PM
If you're sending a fax to a normal geographical number then I'd expect it to be charged the same as a phone call to that number, since as far as I know there's no clever stuff going on to detect that it's a fax.
The only reason they used to charge for dialup is because you'd be connected for hours on end tieing up a trunk on the exchange, where as a Fax usually only lasts a few minutes.
Message 3 of 7
(711 Views)
29-10-2013 3:15 PM
Cheers for the advice, ill set Windows 7 up, send a fax & see if Plusnet decide to charge me for it
Message 4 of 7
(711 Views)
29-10-2013 7:25 PM
I think I'd just rather pay an email to fax service a few pence to send it for me than goto the hassle of finding a machine that still has a 56k modem in it and setting up the drivers.etc
Message 5 of 7
(711 Views)
30-10-2013 9:20 AM
Faxes are counted as normal calls for billing purposes.
Message 6 of 7
(711 Views)
30-10-2013 4:09 PM
Windows 7 Fax & Scan = no need for a stand alone fax machine
My old HP laptop still has a dial up modem fitted so I can use that, all I need to do is connect it with a cable.
Im only likely to send 2 to 3 fax's a month.
Message 7 of 7
(711 Views)
