Anytime Plan
FIXED- Subscribe to RSS Feed
- Home Phone
- Anytime Plan
26-01-2020 1:04 PM
Long time plusnet customer, first time poster here.
I'll cut to the chase, a recent higher than expected bill gave me cause to look through old bills since I upgraded to the anytime plan (ironically because of higher than expected bills)
I've noticed every month since I started this I've been charged for all calls to mobile phones. We're talking over a year here.
What's the crack with this, I'm actually seriously angry I've been charged, isn't that the whole point of an anytime plan?
I'd be interested to know if this is something I've missed in the small print or is plusnet ripping me off?
Thanks.
Fixed! Go to the fix.
Re: Anytime Plan
26-01-2020 1:17 PM - edited 26-01-2020 1:21 PM
What call plan are you on?
"Anytime" is an old plan, (no longer sold but existing subscribers will be left on it unless they change), that did not include calls to mobile numbers unless you paid for an add-on package. The present plan is "Unlimited UK & Mobile calls" which allows 2000 minutes per month of calls to mobile numbers as well as unlimited calls to UK landlines (subject to a fair use policy, I believe).
This link takes you to the current plans:
Re: Anytime Plan
26-01-2020 1:29 PM
I've just looked and it's talk anytime.
As far as I can remember it included uk mobile calls. Cost is £7 per month, plan started on 25/11/18.
Re: Anytime Plan
26-01-2020 1:40 PM
You can find details of call plans ( including legacy ones ) here https://www.plus.net/help/legal/residential-phone-tariffs/#anytime
Seems that after Sep 2016 Talk anytime was only available to existing customers. Looks like there was an option to add mobile calls for £3 /month
I'm sure a PN staff member will be along shortly to clarify exactly which plan you are on
Re: Anytime Plan
26-01-2020 2:19 PM - edited 26-01-2020 2:31 PM
Looks very much like it's my mistake then, I'm angry at myself now.
What I don't understand now is why am I not given the option to upgrade through my account?
It only gives talk anytime international 300 as an upgrade?
So the talk anytime plan is actually £8 and the all singing and dancing plan including mobiles is £9.
Why can't I upgrade to that?
Re: Anytime Plan
26-01-2020 4:00 PM
Hi, I had a similar issue and was able to upgrade via the product change https://www.plus.net/member-centre/product-change option in the deals and upgrades part of the control panel.
Hope that helps
Re: Anytime Plan
26-01-2020 4:07 PM
I even followed your link just now and it's still the same.
Maybe a staff member has the answer.
Re: Anytime Plan
27-01-2020 11:08 AM
I'll wait for a staff members opinion before looking at options, leaving plusnet being one of them.
Re: Anytime Plan
27-01-2020 11:44 AM
I had a similar problem last year when I wanted to change from the Anytime plan to the Unlimited UK & Mobile calls plan. Seemingly, the system could not cope as I had Line Rental Saver in place - cannot see the logic in that but that was the case. It needed the intervention of a Plusnet staff member to sort things out so that I got on to the new call plan without a gap in the LRS provision. Hopefully one will sort it out for you.
Re: Anytime Plan
27-01-2020 4:42 PM
Hi @Muddyfunker
Thanks for highlighting this - you're right that the legacy call package is the reason that you've been charged for mobile calls (as these were not historically included in the package which you have).
If you'd like to upgrade to the UK and Mobile plan, please just respond to this ticket and I'll get that sorted for you.
Best wishes
Dave
Re: Anytime Plan
27-01-2020 4:47 PM
Will respond to the ticket a little later when I finish work.
Appreciate the help 👍🏻
27-01-2020 5:16 PM
No problem at all - just drop us a line here and either myself or one of my colleagues will switch that over for you.
Take care
Dave
