Anytime International 300
cycleboy57
Having recently joined this package, my wife has been diligently recording the times she phones Japan.  Having some minutes in credit, she phoned a couple of friends on 31 Aug.  However, although the bill states CLEARLY that the bill is from the FIRST of the month, the calls on the 31st were included in the September bill.
Can somebody explain???
4 REPLIES 4
Oldjim
Fixes: 63
Re: Anytime International 300
That is because the costs were sent to Plusnet from BTw a few days after you made the call
Chris
Legend
Fixes: 169
As Oldjim says, the call data isn't sent instantly so can take a short while to appear in the itemised bill.
cycleboy57
If that is the case, then trying to work out how many international minutes you have used is tricky. Instead of it taking an indeterminate amout of time, perhaps Plusnet should insert a fixed delay into the calculation of bills, so the user can know precisely on which date the phone call will be allocated.
khorghakh
A quick question about Anytime International 300, is there a way to check to see how much time you have left to use?
