Any way to display caller ID on Windows?
- Home Phone
- Any way to display caller ID on Windows?
03-08-2014 4:38 PM
I have a home phone and ADSL service from Plusnet. I'm looking for a way of displaying the Caller ID of incoming calls, and linking it to a contact list so that it can show the caller name where they are on the list. Does anyone know of the good way of doing this?
I assume that any kind of solution would require a modem connected to the PC - would this sort of thing work? -
http://www.ebay.co.uk/itm/New-USB-56K-External-Dial-Up-Voice-Fax-Data-Modem-V-92-V-90-Windows7-64-ma...
Message 1 of 2
(809 Views)
1 REPLY 1
Re: Any way to display caller ID on Windows?
03-08-2014 7:37 PM
Yes, that would work for you.
You would just need some "caller id" software.
I have used "PhoneTray" for years and it works well but, there are plenty of other options.
Message 2 of 2
(398 Views)
- Home Phone
