Another landline porting question
Racalman
Hi everyone
I have FTTC with fixed IP address broadband and landline and 10 months to go on my contract.
I want to port the number to A&A so I can switch to VOIP. I don't mind losing the phone line for a short period during the switchover as it's not a primary service for me but I don't want to lose my broadband in the process. I don't have any other features with plusnet such as emails etc.
I have read this experience which doesn't sound promising 😱.
Is their any guidance from plusnet on this? Do I ask them to migrate me to a SOGEA account? If so do I have to pay to leave my existing contract?
Thanks for any sage advice.
Mike
18 REPLIES 18
Fixes: 116
Re: Another landline porting question
@Racalman
You cannot port your landline until you are on a SOGEA connection (or Full Fibre if and when it's available).
You ask PN to transfer you to SOGEA - I believe it will require you to start a new contract. Once it is confirmed you have migrated then you can initiate the number port.
Given the low cost you can set up an A&A account with a generic number to ensure your phones work with VOIP is you think that's worthwhile.
You can phone the PlusNet Customer Options Team on 0800 013 2632 to confirm things.
Fixes: 382
@Racalman That 'experience' is from two years ago, before the 'one touch system' and other changes were implemented. I have not seen/heard of any major problems of that type for quite a while, and to be honest, I  doubt you would come up against any.
Yes, if you want to move your voice service to VOIP, while retaining your FTTC  service, then you do need to ask PN to switch you to SoGEA. You have no penalties on you existing contract but AIUI,  you will be placed on another fixed-length contract.
Racalman
Thanks you Brian for your prompt and helpful reply.
Mike
Racalman
Thank you John much appreciated.
Mike
HPsauce
All Star
Fixes: 5
@Racalman You need to check/confirm if a fixed/static IP address would be available after a change to SOGEA; I suspect not. Depends how important it is to you of course.
Fixes: 245
Fixed IP addresses 'live' with the account not the service.  Changing service on the same account will retain the fixed IP address.  There have though been some issues where something fails, requiring manual intervention to refresh the broadband component on an account to recover the existing fixed IP address.
Fixed IP addresses are no longer available to those who do not already have one.
mystreet1
Seasoned Pro
Fixes: 7
Also check when the best time is to swap. Don't forget the annual price rise as you may get an unexpected rise a month or two after starting the new contract.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Racalman
Thanks for the tip. I will bear that in mind!
Mike
markhawkin
Champion
Fixes: 21
I certainly would leave any renewal until (perhaps) May.
I don't suppose full fibre is available or in the offing at your address.
I did the move to VoIP as part of a full fibre upgrade (with a more critical need for limited downtime on the landline) and it worked fine.
Get the A&A VoIP service going a few weeks before you want the number port so you know it all works and it should be fine.
Racalman
Virgin are the only suppliers of FTTP in my area but I don't want them.
Mike
Racalman
I took Brian's advice and phoned the customer team. They confirmed that the fixed ip address will remain when I move to SOGEA and that my landline number will be quarantined for 30 days during which I can port it.
What could possibly go wrong ...
Mike
Fixes: 116
@Racalman
Just don't start the number port until you've got confirmation you're on SOGEA - things can go wrong if you jump to early.
Racalman
@bmc wrote:
@Racalman
Noted! I'm planning to do the switch by phone so I can get them on the recording if things don't go to plan 😀.
I won't request the port until my line goes dead.
Mike
Racalman
I decided to get on with it and arranged the switch to part fibre, which happened today. It was seamless, probably because I have my own router and a fixed IP address. If I hadn't had an email from plusnet I wouldn't have noticed!
However the landline still rings and has a dial tone. How do I kow when it's safe to port the number to A&A?
Mike
