Another caller ID not working
Baldric
We have noticed that our caller ID is not working having recently moved, we are using the same phone a before that used to work, can it be checked that caller ID is set correctly at Plusnet & your suppliers? This seems to have been a common issue with a few people recently.
3 REPLIES 3
WillF
Fixes: 22
Re: Another caller ID not working
Hi @Baldric, the Caller Display feature looks to have not carried over correctly in the Openreach phone system. I've re-added that for you, this should be done within 24 hours at the latest.
 Will
Baldric
Thanks, that is now working.
WillF
Fixes: 22
Great, thanks for confirming that @Baldric Let me know if you need anything further!
 Will
