Anonymous call reject blocking mobile number
- Home Phone
- Anonymous call reject blocking mobile number
11-10-2014 12:11 PM
Since I had Anonymous Call Reject activated my mobile number which has Caller ID activated is being blocked, why?
Message 1 of 6
(1,143 Views)
5 REPLIES 5
Anonymous Call Reject not working
11-10-2014 12:14 PM
Despite having Anonymous Call Reject and Caller ID activated I am still receiving calls showing as Unidentified Number. Why? What are the limitations of Anonymous Call Reject?
Message 2 of 6
(694 Views)
Re: Anonymous call reject blocking mobile number
11-10-2014 12:32 PM
Two posts on the same subject merged as they may be related
Message 3 of 6
(694 Views)
11-10-2014 1:03 PM
Thanks for posting.
I’ve tested this by calling you from a withheld number and, as was expected the call was blocked. I’m not sure why your mobile is being blocked. Have you been able to try to from elsewhere to try to replicate it?
Unfortunately not all calls are rejected by ACR. A small amount of call will get through where the number of the caller isn’t hidden but is not available to us. This tends to happen with international calls.
Tony
Thanks for posting.
Tony
Message 4 of 6
(694 Views)
12-10-2014 10:37 PM
Thank you for your reply and explanation re ACR and international calls. As for my mobile being blocked mysteriously this seems to have resolved itself, not sure why!
Message 5 of 6
(694 Views)
13-10-2014 9:26 AM
Well I'm glad it's resolved itself ajpee because I'd have been stumped with that one.
Let me know if you ever find out what caused this in the first place
Matty
Matty
Message 6 of 6
(694 Views)
- Home Phone
