All singing, all dancing but NOT Ringing
- Home Phone
- All singing, all dancing but NOT Ringing
22-11-2014 1:12 PM
Re: All singing, all dancing but NOT Ringing
22-11-2014 1:19 PM
Welcome to the forums.
All infrastructure provision (and therefore issues) lay with BTOR. Essentially PlusNET only manage the service interface and billing.
One thing to double check is that the right number is on the line. BTOR screw-up on line numbering is not uncommon.
If you dial 17070 the automatic test service will advise of the 'service' number assigned to the line. It might not be what you expect.
Kevin
22-11-2014 4:00 PM
22-11-2014 5:05 PM
Sounds like you have done all of the tests, and as such its almost certainly not your own equipment
I can see that the fault is currently progressing and hopefully we will be able to get this one resolved for you sharpish,
22-11-2014 5:27 PM
You don't need to disconnect your current router / modem - just plug it in where you would plug the phone into.
22-11-2014 9:13 PM
Quote from: itsme some phones still require the ring tone on pin 3 and the master socket supply this to the extensions.
The filter facilitates this.
24-11-2014 9:50 AM
05-01-2015 3:47 PM
Keep up the good work!
- Home Phone
